I have a question about the OCK-1. Well a few questions.
1. Is it generally agreed that adding the OCK-1 is a noticeable improvement in SQ?
2. Does this clock operate with both LAN ad coax? I'm a bit confused about the above posts saying it doesn't work with coax, want to use it with my CD transport as well as LAN
3. Is i2s the best way to connect it to the R26?
This is an answer from Gustard regarding the use of a 10Mhz external clock with the R26 and when its clock signal is used to reference the internal K2 synthesizer and when is not used.
When playing PCM
1. PCM NOS: OFF
The improvement provided by the external clock applies to all R26 inputs.
2. PCM NOS: On
The improvement provided by external clock applies to USB and LAN inputs, IIS AES coaxial optical Bluetooth does not apply.
When playing DSD
1.DSD DIRECT: OFF
2.DSD DIRECT: ON
The improvements provided by the external clock apply to USB and LAN inputs, IIS AES coaxial optical Bluetooth does not apply.
When playing PCM
1. PCM NOS: OFF
2. PCM NOS: On
When playing DSD
1.DSD DIRECT: OFF
2.DSD DIRECT: ON
Interesting - cheers. I think I'd only read a truncated version of this. and when I've played content via spdif inputs its only been Netflix and Cable TV etc so the smoothing effects of oversampling (NOS off) was better than NOSon, notwithstanding that based on what you say the external clock is in play in NOS.
Edits
- sorry.. I skim read, so it's a response from Gustard - no wonder. Much appreciated.
- need my morning coffee before I post more, Oversampling, Non-oversampling and NOS off/on double negatives always do my head in.
- there's generally a really audible click/interruption when switching from internal to external clock and back, none whatsoever with s/pdif in NOS off mode so I'd assumed it wasn't in play. Will test various scenarios tonight in line with Gustard's response.
When playing PCM
1. PCM NOS: OFF
2. PCM NOS: On
When playing DSD
1.DSD DIRECT: OFF
2.DSD DIRECT: ON
Has anyone managed to find an app that emulates the R26 as a Chromecast receiver? That would be very handy to stream directly from most streaming services apps
What are people using for the BNC cable between the clock and the R26? Sorry for the simpleton questions, a week ago I couldn't spell BNC, now I have to get one.
A 50ohm BNC cable is what you want, generally 1m or less. I have a Gustard C2 cable which is recognised as being good (alas there are differences, the scientific testing community has various grades of higher and higher precision low and internal reflection test cables into the hundreds of dollars btw) but there is a much cheaper but good one mentioned in this and other threads I can't recall right now sorry. Gotta go to a meeting but if I recall it I'll add the name to this post.
I've read a bunch of guys use Belden cables and I'll be looking for one now too. I just ordered a OCK-1 as it specs out just as good as a C18 at 1/4 the price and guys on here that have them are quite happy with them.
I've read a bunch of guys use Belden cables and I'll be looking for one now too. I just ordered a OCK-1 as it specs out just as good a C18 at 1/4 the price and guys on here that have them are quite happy with them.
I try to build or buy the best cables I can afford, nothing boutique in my system, but all very decent stuff. I understand the importance and impact of every piece of wire and (yes) foil, but honestly have no idea how important this BNC cable is. But over time, every objectivist (it's just 1s and 0s) trope has fallen flat on its face. I'm sadly going to assume the same goes for the BNC
