shrimants
- Nov 8, 2006
I have a project that i've been brewing up in my head. i want to make a pair of 4-way passive floor standing speakers.
So far I am in the "research" phase of the "Research and development" step.
I'm thinking I will have a ribbon driver as a tweeter (though a "normal" tweeter would be fine i guess), a 3 inch kevlar woofer, a 6 inch kevlar woofer, and either 10 or 12 inch subwoofer in each tower. (probably 12)
The subwoofer will be isolated in its own sealed chamber at the bottom of the whole speaker. I would like it to be front firing, but down firing is OK too (i just havent done research on down firing).
I still need to research cabinet interior design and "order". I keep seing things about 3rd order and 4th order cabinet designs.
I have been reading about active and passive crossovers. I read that active crossovers are usually preferred unless you have a VERY simple design (which this is not). I know that active crossovers mean I'll have to have one that either has amps built in or have an individual amp for each "line" of the crossover. I'm not 100% sure about this info. I was thinking of using either the UltraDrive or the SuperX. One for each speaker in 4-way mono configuration. http://www.behringer.com/EN/Category/Signal-Processors.aspx?s=E150 I figured that would serve as a temporary solution and I could build my own crossover/amp unit for each speaker as time passes for even more upgrady-ness. It would be amazing to incorporate a tube amp or 4 into this somehow.
i was thinking MDF for the cabinet design with some sort of nice polished wood paneling like oak or mahogany.
I just have no idea what to start reading and understanding because the articles I see are either way too simplified or way over my head and lacking any sort of formatting to boot.
