As promised
@RumbleWeed
TL;DR: In reality, the GD3A is all you need. They've got bass, controlled mids, and very resolving treble that doesn't send an ice pick into my treble-sensitive ears. If you want your mids to be way more forward, get the GD5. Like their naming scheme might suggest, the GD5 is literally the tuning middle-ground between the GD3A and the GD7B.
Pictures first:
GD3A:
GD5:
And for comparison, my existing GD7B which are dressed like the SD3:
The full lineup:
Okay, so aesthetics before sound, because pictures are hard:
- The GD3A are a significantly richer shade of blue than I was expecting, and I tried my best to make sure that showed in the photographs, but my phone camera is being incredibly contrary about these things.
- The GD5 are practically impossible to photograph because of how much sparkle they have and how much color shift the polychromatic foil in their resin can undertake at even slight shifts in the angle of the lighting. I tried to capture that effect in the photos as well, since it can shift dramatically from green through yellow, orange, red-violet, violet, and then to a cobalt blue hue. It's a lot of color shift to take in and I can definitely say that the green-yellow tone is definitely not my preference, so glancing angles of light aren't my friend in regards to that.
- I opted to throw in my existing SD3-shelled GD7B to show how comparatively muted its purple color scheme is compared to these other sets. Still pretty, though, in my opinion.
First listening impressions, no burn-in, no tip rolling:
- The GD3A sound wildly different to what I've grown accustomed to from my GD7B, mostly due to the fact that the bass and treble have been elevated and the mids recessed. It's not necessarily a bad thing, as songs sound quite nice. The mids are well balanced in their treble transition so that female and male vocals get about the same amount of gain. In my very brief listening I didn't notice that one sounded more forward or recessed than the other. Surprisingly enough, despite their considerable treble gain even over the GD5, I didn't find their treble to be all that problematic and I'm usually quite treble sensitive. I'll make sure to update on whether that continues to hold true while I burn them in, but they're very pleasant to listen to. Bass has significantly more gain than I was anticipating and the treble is very smooth yet resolving.
- The GD5 is basically the tuning middle-ground between the GD3A and the GD7B. Mids are more forward, but the added treble gain and extension provides a bit more air while the extra bass gain gives you more oomph when the songs call for it. I had been watching Youtube videos on my computer through my KEF iQ90 tower speakers when these sets arrived and when I put in the GD5 and switched audio outputs over my first thought was "Oh, these are basically my towers in IEM form." With additional listening, I do think the mid-treble needs a bit more time to break in, as some of the notes aren't quite as delicately handled as my KEFs can manage it, but, well, my KEFs cost something like $1400 new and are running off a receiver that was $900 when new, so yeah. For a $130 IEM to give me strong KEF vibes is quite impressive. My only complaint is that the little spike in the treble that shows in their graphs is audible to me, so it's most likely hitting on one of my natural harmonic peaks. I'll need to do some tip-rolling to try and help resolve this, but I'm quite impressed overall.
I showed the
new bluetooth neckband I picked up off AliExpress in that final photograph because, well, it works surprisingly well. I can confirm that it is, in fact, capable of LDAC codec use, but my phone won't let it because it isn't broadcasting compatibility with it. I don't know why this is the case, but I'm just going to let it slide because APT-X is sufficient for the majority of my listening needs at the moment anyway. If you have a way to force it to use LDAC, the extra resolution is nice, and the range and battery life are actually pretty impressive, even when using LDAC. I'll have to check back in with the seller at some point to see if they can put me in touch with someone that can get me a firmware update or something to get it to more generally support LDAC.
Edit: The tip-rolling odyssey has begun. The bass-boost tips from the Geek Wold GK10 were a failure at reducing the slightly hot treble. Swapped to foams, but the sound became too... ...enclosed sounding? Swapped for Sony Triple Comfort tips and they seem to be helping. I don't think they're the ideal solution, but they cut enough of the treble to be more than serviceable.
