Takaji
- Jan 16, 2008
I've been trying to figure out how to eliminate the annoying static-like hiss I'm hearing from my monitors. So far, the only solution I've found is to unplug the power supply to my laptop, which is really just a temporary fix.
My setup:
Laptop ---USB out---> DacMagic ---Balanced out XLR---> Mackie MR8 Active monitors.
Both monitors are plugged into the same electrical circuit as the computer. These devices are connected by grounded plugs. The DAC is connected via ungrounded two-prong wallwart transformer to another power bar that is connected to the same power bar as the monitors and computer.
I read in other posts that using a SPDIF connector from the computer to the DAC can help reduce ground loop problems. I tried that, and it didn't work (it only reduced a small amount of noise).
I also read about a power device that plugs into the end of any cord and then into the wall, and is said to remove any noise from a power source.
I'm sure that this noise is originating from my laptop, as I've plugged my LiveWires into my laptop's sound card and can hear the same thing.
Any ideas?
My setup:
Any ideas?
