appar111
- Jun 4, 2002
I would agree with you-- alot of it isn't so much keeping it from coloring the sound, so much as finding how the amp coloration compliments the headphone coloration, source coloration etc. Then again, for some the object is to find the most neutral source, amp and headphones so that they minimize the need to find components that compliment each other with regard to coloration.
Originally Posted by BowerR64 Im sure ill catch heat from this but the way i see it no one really likes me round here anyway. Amps color sound IMO, depending on the make or model you add. With an amp your gona add warmth (if its a tube) or its gona add bright (if its solid state) it all depends on what amp you use, just like it is the type of headphones you use. Its not gona just amplyfy the signal its gona color it. |
