GreenBow
- Feb 6, 2015
Canadian Maple works well on the cups.
Alright thank you.
My suggestion would be to buy them, its a lot of work to make the cups and its not just using a hole saw bit, most are made using a lathe, and you will still need to finish them and get grill material. Check out these https://www.etsy.com/search?q=grado%20wood%20cups
I looked at this website a few times. I didn't see mahogany before.
Some of those are a better price than I expected like the mahogany at £55. It might be a better option than making, because the drill bits will cost about £90. I was thinking of making a straight edged cup like the RS2e though. Then I was intent on salvaging the grill from the discarded 225e plastic cups.
