Dewd
- May 2, 2013
Hello everyone! I've heard about the famous "grattle" that seems to happen to a lot of Grado headphones. I've read that it's normally just hair inside the headphones but my hair isn't that long and I don't seem to hear any debris inside of them. There is rattling in both ears and it's driving me crazy! People have mentioned a "wrinkle" in the diaphragm and I think that might be it but I can't seem to reach the diaphragm as easily with this particular model. I read you have to use some duct tape to align the diaphragm or something and then use a hair dryer to fix the crease. The problem I think is the white see-trough paper thing with the holes that I'm not sure can be removed but I'm guessing is where the diaphragm is. If there is a way to reach the diaphragm with this model that won't put my poor earphones at risk I would be more than happy to hear it! If there's another way to fix this problem that would be welcomed as well. I'd rather try to fix this myself because I don't think I want to send it in and wait 3 months to listen to my music again . I'm relatively new to this so if you can dumb it down a little for me . Thanks in advanced!
