Gippy
- Dec 2, 2016
I received the G-pads. So far, they are exacerbating the brightness issue. However, I will try some different setups before I condemn the pairing.
The G-cups increase the treble and suck out the midrange, which is why I feel they're no good except on the Grados that come with it. Even then, the midrange is recessed in order to expand the soundstage. I still had to EQ up the mids on my GS2000e.
I suggest you return the GH1 and just get the RS1e, which is reportedly the least bright in-production Grado due to having the 50mm driver in a L-cup config. The 50mm drivers are tuned dark to offset the brightness that the G-cups bring. For best results, make sure the RS1e has the brown headband. This guarantees that you have a newer production model where the drivers are level with the wooden cups.
