Thank you everyone, more questions.
Originally Posted by Steggy /img/forum/go_quote.gif
what program do you use to play the FLAC with
but yes, the grados will be a step up. 280s are closed which limits its soundstage. you'll notice a difference with the 225s. although it also depends on the music you listen to. grados are more for rock while i think the 280s are really bassy so they would be for hip hop
I don't have the macbook yet, I'll have one in a few months, but it will be my primary source. I'm using winamp right now with the most popular FLAC plugin they have on their site. I will actually use winamp on the macbook as well when in windows, and itunes while in mac mode, for my ipod.
I listen to a ton of hip hop and electronic music, the two combined make a plurality of the music I listen to, but it's still only like 20 percent. I listen to a big range, but good bass is important, both going low and having powerful presence.
Originally Posted by WittyzTH /img/forum/go_quote.gif
check your media player first. then check your MacBook. The problem isn't from HD280 I guess.
Probably you may need to spend your $200 for new source instead.
What do you mean check it, and what do you mean new source? Sorry, I'm new to this.
Originally Posted by steinba /img/forum/go_quote.gif
I'm guessing they distort because the Macbook's headphone output isn't able to deliver enough power to drive the headphones to the listening level you want.
How about trying a small amp?
What kind of cost are we looking at, and can I still use the headphone jack for the macbook? The reason I ask is it doesn't have another non-powered, or whatever the term is audio out. Suggestions?
Originally Posted by MD1032 /img/forum/go_quote.gif
100% sure it's either the recording or the Macbook. The HD-280's are fine phones, although I prefer the SR-225's by a very significant margin.
The FLACS were done to 99.9 to 100 percent on EAC...
Originally Posted by moogoob /img/forum/go_quote.gif
Get an inexpensive amp/DAC combo (I use the Headroom Total Bithead) and you'll be golden. Both your 280s (I still use mine when I need isolation) and Grados will thank you.
225s are very nice, 325is are nicer, but not everyone can stand their crazy/beautiful sound.
Also, one thing you might not be used to with the Grados is actually turning your equalizer off. I find the 280s sound best with a mild "rock" curve to mellow their honky mids, Grados neither need nor react very well to crazy headphone fanatics fooling around with the EQ sliders.
Tell me about the amp/DAC combo, what does DAC mean?
What are the differences between the 225s and the 325is? Why is the latter crazy and beautiful?
Originally Posted by moonboy403 /img/forum/go_quote.gif
I think the general consensus is that the hd280's bass is definitely there and it extends really low, however, the impact of the bass is lacking.
That's exactly how I feel about it. I like the range but I want some more impact. Will the Grados deliver this?
Thanks again, you all have been very helpful. I'm a college student on a budget, but I really care about sound quality. I've been reluctant to get into this because of my low budget, but I have to at least get an amp and better cans. I'm maybe not ready to go taking apart a soundcard and improving it myself....yet.
