Michgelsen
- Apr 2, 2007
The m903's USB interface is ground isolated so the computer ground is not connected to audio ground. It sounds like it could be a ground loop with the computer ground and your amp ground. Have you tried a ground lift adapter on either the amp or on your computer? You could also try plugging the amp in to a different outlet to see if that helps.
Yes, it seems to have worked! Thank you very much for your support!
I have now connected the amp to a different, ungrounded outlet and the noises are gone as far as I can tell. I wouldn't have thought it would be a grounding problem, because it sounds so different from previous ground loops I have encountered, but I'm glad the fix turned out to be so easy after all.
Previously, I had tied the chassis of the amp to a real ground, and grounded my whole system through that, because all devices share their ground via the power strip, but the power strip itself is not grounded. (I have no grounded outlets in this room.) Now I have grounded the computer case instead, to ground everything that is connected to the power strip.
Am I right in assuming that the chassis of the amp is still grounded via the rca cables > m9xx > usb cable shield > computer now (and that this was completing the loop, via the power strip)? If I leave this system completely ungrounded, I get a slight hum from the amp, and get little shocks from the computer case, so I need to ground the system somewhere. I guess the current setup works.
I hope the next iteration of the m9xx can have a ground isolated usb input again. It would make hooking everything up much easier. I would gladly pay slightly more for this. Does the m920 still have this?
