When you're subscribed to Massdrop, you don't look. It finds you.
+1. Massdrop and Head-fi together typically lead to accelerated spending!
Yes, it can be used as a preamp. The manual is linked on the MassDrop page.
As for "better", only you will be able to tell that, but chances are any difference will be very slight.
I'm still kind of confused on the hybrid volume control design: Is there a potentiometer involved? When is the volume controlled in the digital vs. analog domain?
I personally do not think the m9XX is overkill for anything. Even more sensitive headphones sound great on the m9XX, as the volume (even on High Power mode) elevates slowly/slightly as the volume number increases.
The iPhone 6 can be used as a source with the m9XX if you use this: http://www.amazon.com/Cute-USB-2-Port-Splitter-Black/dp/B00FJG5T4W/ref=lp_7583942011_1_1?srs=7583942011&ie=UTF8&qid=1445921860&sr=8-1 (@HiFiGuy528 posted this as a solution earlier in the thread). Mine (I chose Black) will be here in 2 days. Reflected in my review.
I just don't understand what the splitter is doing. In the picture you had one link from the phone going into the splitter and the other is empty. You weren't using it as a splitter at all.
I did not post an iPhone 6 and m9XX connection, as the hub that I originally used (Gear Head 4-port USB hub) did not work for me. The photo in my review of the connection is of the Samsung S5 and m9XX via USB to USB male and Sony external battery charger. My Cute USB hub is on its way (will arrive tomorrow), and I will update the review with pictures of my iPhone 6 and m9XX connection.
Look at post 74. That clearly shows an iPhone 6 plugged into that "hub"/splitter, but only one port of the splitter active.
Sorry if this was covered but hard to sift through everything...are the RCA outs on the back variable? Thanks much!
