And how do you come to that conclusion? I can tell you in comparison to many other amps I've heard the 880s with the LDIII is not up to the task. I know it's rated upto 600 Ohm as are most amps, even sound cards for that matter but it's little more than marketing.
Um, let's try again.
1) LD rates the amp for phones up to 600 Ohms
2) David from LD confirmed the amp can comfortably power the cans
3) Based on lines 1 and 2 above, we come to 3. 3 = I tried the set up, and based on the fact that in my set up it easily drove the DT's, my 'conclusion' as you said was reached. I also compared to several other more powerful amps and the LD was not lacking.
Clearly you disagree. That's your right. But that doesn't mean both the manufacturer and I are wrong, because you disagree and don't think it's "up to task". I would be VERY careful with your statement about their claim being 'marketing'. Basically, your saying they are dishonest in their claims.
Again, because you don't like the combo, doesn't mean it's "not up to task". Not sure if your aggressive tone is intentional or accidental. If it's accidental, that's no prob as we've all come accross the wrong way on forums before. If it's intentional, then respectfully, I'm not going to waste my time going forward with someone that is out to save us from "those eveil corporations that lie about everything with their evil
marketing". LD, from what I've read on this forum, has an outstanding reputation, even with the occasional person casting unfounded accusations.
Jeeshhh.
