Originally Posted by johnzz4 /img/forum/go_quote.gif
Though I've never heard the Beyer DT-250's, you may want to look into those as well based on what I've read...
I own both the Beyers and the AKGs, and while I like the DT250, the K 272 is much more transparent, has more depth, has better bass, and has a better cable situation.
On the flip side, the DT250 has an inoffensive sound signature, and is slightly more involving - in that respect it may be a stronger all-rounder than the 272. The 80ohm version is also easier to drive than the 272, and it leaks less sound (although, weirdly, it blocks out less sound).
For the cosmetically minded (like those with piercings), the DT250, while "old-looking", has a much thinner profile, so it isn't nearly as embarrassing to wear when you're out and about as most high-end headphones.
But for this guy, I would solidly recommend the 272 over the DT250; I think it just sounds better overall, and it's also $50 cheaper last time I checked.
