whiteshadow001
- Feb 1, 2012
Awesome. Be sure to come back and share it how sounds. That's always a help to other people researching in the forums![]()
Will do man, I'm always looking to help people whenever I can
I'm looking for a system that won't break the bank but will better than my 5 year old Samsung system. I've been looking at energy and Polk systems. Any other recommendations are greatly appreciated. I mainly play video games if that helps.
Sent from my Galaxy Nexus using Tapatalk 2
Just keep in mind you can't compare DTs frequency response specs with other speaker companies. Their low end ratings are often not where the speaker/sub rolls off, but beyond that to where they are not producing usable output.
The MLT-2 is definitely a better set over the DT 60.6. More powerful sub; bigger drivers in the speakers.
I would also recommend looking into a factory refurbished/factory warrantied Denon 1612 at accessories4less.com. Better receiver than the models you are looking at. Comes with Audyssey MultEQ, which is worth having since EQs the speakers and the sub. No line out, but then again, better not to mix your Swans with the center channel of the other speaker model because of the different timbre match. Your front sound stage should have exact matching speakers, or the matching center.
DT is known for basically lying about their specs. For example, the Pro Sub 800 is rated by DT for "20 Hz - 150 Hz." Independent measurements show that sub is -28db down at 25hz from it's peak at 62hz. So I just don't trust anything DT claims about their speakers. Paradigm/Martin Logan, on the other hand, is known to be much more truthful with their specs. So is the DT better? Doubtful. What can you learn from reading their specs? Only that the performance will definitely not exceed what they are listing.
And I didn't realize that the Pro Monito 60 speakers have passive radiators. I know that the 600s don't.
OK. I thought you were talking about using the Zone 2 line out as a speaker A/B option to switch in the other speakers.
Thanks for the heads-up, really appreciate it. Looks like I'll just keep my money and wait around for what I really want, which is to use three Wharfedale 9CS (center) for LCR, which I'm planning to get used. They're cheap over here but I'm even cheaper so I'm waiting for used units; unfortunately I haven't got any responses from three different people of the same color. And of course anyone buying the whole 5.0 or at least 3-piece set from them gets priority on the sale. They're around $100++ or so brand new but used units go for around $60 with no cosmetic or other issues.
Which Kef?
You mean the KEF KHT1005.2SE? Sorry. I don't know anything about them. But for $199 at Newegg certainly seems like they could be a decent deal.![]()
