A.Thorsen
- Feb 26, 2006
Wow!
Originally Posted by nierika Whoh...welcome back Justin! |
Wow!
Originally Posted by grasshpr I'm not exactly sure what gain the gilmore lite is using but with at least a gain of 5 or so I can notice some noise from the output. |
Originally Posted by Svperstar I'm sorry if I am misunderstanding you but are you saying there is noise in the signal due to the Gilmore lite? I completely disagree with you, I have tried different sources and different cans on my GL and have never noticed anything but the music, no noise at all. |
Originally Posted by grasshpr Keep in mind these are MY impressions of the Gilmore topology (NOT of the Gilmore lite since I don't own one). |
Originally Posted by grasshpr I'm pretty sure that I'm making it clear that the noise is from the high gain amplifier (as no amplifier is perfect with respect to noise). All amps have some noise and to what degree depends on your hearing sensitivity and the types of cans you use (e.g., low impedance cans are typically very susceptable to amps that are typically built for high impedance phones, however, amps built for low impedance phones typically don't provide enough power to high impedance cans). Keep in mind these are MY impressions of the Gilmore topology (NOT of the Gilmore lite since I don't own one). However these designs are almost identical and I was just putting my two cents in to help other discern my impressions of this TYPE of amp. If you don't notice them, more power to you! These are purely what I've noticed by testing with the rigs that I have. If you don't get any noise then that's great! |
Stay updated on HeadAmp at their sponsor profile on Head-Fi.
Originally Posted by grasshpr I am however still able to discern some noise at gains at around 5 with the e3c's. Very slight at that level though. I should apologize about making an erroneous statement that Gilmore topology would not work well with low impedance cans. With proper component choice, this shouldn't be a factor. Thanks for setting me straight Justin! |
Originally Posted by justin w. Any voltage amplification you do will just add unnecessary noise & amplify noise coming in. |
Originally Posted by justin w. There's no need to run anything over unity gain (1x) for the E3C or similar phones. |
