- Dec 27, 2010
Wow positive, I'd say...
Sorry to hear you are having issues as well. My lid is very tight and I had to pull it up from the back. Take your time it will lift out exposing the card slot.
I unfortunately have not been able to get the unit working and have for the first time found customer support somewhat lacking in both response time and helpfulness. I was initially instructed to follow the re-flashing instructions on LH's website and I felt I had except what I wasn't clear on was that the mSD card you use must be formatted with FAT or FAT16. The problem is FAT16 can only be used on cards 2gb or smaller. The smallest card I could buy in my area was 4gb and though I selected the FAT16 Windows used FAT32. At least that's what made sense to me at the time because I could still see all 4gb of space. I then downloaded a 3rd party software (Active Partition Manager) to force a 2GB/FAT16 partition but that did't seem to work. I was finally asked to repeat the process but to also re-flash the main firmware as well as the MCU ... and to disconnect the unit from the LPS and use the wall wart. Just received a 2gb msd card earlier today from amazon ... repeated everything and still no luck.
Hey ... when you tip your unit towards the ceiling and then the floor do you hear a slide/clicking sound?
I do. Wonder what that is.
Cheers
Sam
Rest In Paisley Prince
Cheers
Sam
I tried flashing the MCU, but it didn't appear to do anything. When selecting firmware version to check, the display totally dies (though power still on), which was one of the original symptoms. Sending back for repair. Sorry to hear about the sliding/click sound. I don't hear that but it does seem like an undesirable mystery.
I still have money tied up with GO V2, LPS 8, HPA and PULSE TUBE...
Well the INFINITY has finally died.
Started with a dodgy SPDIF 1 & 2, then with further testing I discovered that TOSLINK doesn't work.
This evening, it won't handshake and connect to my Mac despite power cycles / new USB cables.
Finally connected for a few seconds before randomly disconnecting.
The BLUE needs to go back, as the dodgy PCB assembly means the SPDIF only protrudes by 4mm (vs the 6mm for RCA) - meaning that cables don't connect properly.
Back to the GO1000 for a bit, and hoping to hear from Larry & Co, and that they'll cover the S&H for the SECOND RMA of this stuff.
Not impressed at all, and still have money tied up with GO V2, LPS 8, HPA and PULSE TUBE...
Could be worse...I'm waiting for the fully tricked out Wave, Source, and Vi Tube Dac...came to my senses when the amps were being funded, a bit late, but better than nothing.
