Geek Pulse: Geek desktop DAC/AMP by Light Harmonics
Jun 26, 2015 at 3:46 PM Post #8,208 of 13,808
What? With all the bla bla bla found on the label. They will not believe it?
Sometimes "too lawful" is also unbelieavable.
Jun 27, 2015 at 1:24 AM Post #8,211 of 13,808
I believe that I got the last one, before they ran out. I had tried different USB combinations, which led to frustration. I believe the Pulse was designed to be connected to the LPS with the 2G cable.
Jun 27, 2015 at 9:48 AM Post #8,216 of 13,808
OK, what is the difference between this, say, and a power conditioner you would use for audio and/or video?
Jun 27, 2015 at 11:24 AM Post #8,218 of 13,808
Some sort like this
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR12.TRC2.A0.H0.Xpower+distributor.TRS0&_nkw=power+distributor&_sacat=0
So the link, at least when I click it, goes to a long list of distributor caps for Power Ram 50 trucks. What am I missing here?
EDIT: OK, just noticed I can filter this by clicking surge protectors and power strips, which I assume is what you are talking about.
If the idea is that a metal casing helps isolate/shield the power outlets, here is a simple low-cost option (albeit not as "sexy" as those more expensive cases at ebay): http://www.guitarcenter.com/Live-Wire-Power-Strip-with-10--Cord-106080807-i1790187.gc
They are easy to open up and disassemble, and you can even roll your outlets if so desired. I'm using one as a chassis for a simple AC filter with remote trigger. They include a simple filter and surge protection, but those can be easily removed. BTW - these are identical to the Furman SS6B which are about twice the price (only difference is a 10' vs. 15' cable).
