walfredo
- Aug 7, 2010
Yeap. I tried lots of stuff.![]()
Does it work with the original power supply that came with it?
Yes, it works fine. But, FWIW, the original power supply is rated at 2A.
I would try to measure the voltage under load. Some supplies can sag considerably under load. If you are measuring it with no load at 12 volts...
You could measure current.. if you have a meter that will measure up to at least two amps. It would mean cutting one of the wires and putting your shunt... or meter in series.
Bottom line, you supply doesn't cut it for the Pulse.
Anyone purchase and have received their Audeze LCD-2 headphones from the campaign?
Me tooI received them about a month ago.
anyone has any idea what this is?
https://www.indiegogo.com/projects/vi-high-performance-crowd-designed-audio-system
they have come up with a new campaign to milk from geek soul backers?
Any ideas how the amp on the Geek Pulse xfi + LPS would play with the Alpha Prime? Also how would that stack up to the ifi micro idsd? Comparisons of both the DAC and the amp are welcome. Also what about the centrance hifi-m8?
That is the Geek Soul, newly renamed!
Yes, that appears to be the case.![]()
Did anyone outside USA, but not Asia, got their HiFiMAN can? I haven't had any notification that it's been shipped, a tracking number, or anything like that... I am considering opening a ticket by this time.
Care to tell us exactly what LPS that is? Others may want to avoid it...
Or are you going to work with the seller on a replacement?
It is a DC-1 LPS, available from ebay by many sellers. For example, http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.XHifi+linear+power+DC-1&_nkw=Hifi+linear+power+DC-1&_sacat=0
To be fair, the never advertised it would work with the Pulse. I assumed so based on the specs. I need to measure current to make the claim my unit indeed falls short of spec. I am thinking a way to do it without destroying the cable.
