pauldgroot
- Oct 16, 2013
So why no word about the Xfi shipping out? I thought that was supposed to be in parallel right?
Hot damn, awesome. Thanks!
Looks like I'll have to boot into Windows to update, as the tool doesn't exist for the Mac as far as I know.
Axel, I know they're working on a Mac DFU.
[Insert generic complaints about things that require additional work taking additional time to complete]
haha I'm a moron I was trying to figure out how many resistors were going to be set aside because they said they have 500 and that was enough for 125 pulses for hand matching. Then I realized 500/4 is 125. I guess 500 resistors is a high enough number that they should be able to closely match them all
The fix is to have the default set to around -80dB.
Now the default changes from -0dB to -80dB. So this is VERY safe for anyone.
If -80dB still too high for you, I would suggest you change gain settings to LOW.
What are the power specifications for low gain? With the GO 1000 and fairly sensitive closed-back headphones, -80 dB on the LH Control Panel is my normal volume level with modern music. :/
