eac3
- Mar 8, 2013
I'll compare against the geek out, probably a little less lean. My chain is pretty lean/analytical right now so it's harder to discern what is the DAC and what isn't.
You would probably be a good candidate for the tube buffer, honestly. You can't get detail and resolution back, but you can warm up things after the fact.
The Yulong DA8 is a bit lean. Great control over music it just squashes some of the decay in the music. Im not sure if its a Sabre thing or a specific manufacturer thing. Id like more warmth too, being a tube guy. Id go with a tube preamp vs a buffer, but the Pulse is a preamp already isn't it.
Check out the specs at https://docs.google.com/spreadsheet/ccc?key=0AljAXIFo7qVqdFdmVUoxOXB1VzFPaGtkQXdRa01ibUE&usp=drive_web#gid=1
X has dual mono design, so basically 2 pulses in 1! (OK that's simplifying things a bit!)
I went Xfi rather than Pulse, just to future proof really and, at the time, the cost difference was not that great. Just got to decide if you're going to treat yourself for Christmas!!
Edit; Forgot to mention that the X has single ended RCA's as well as balanced XLR outputs.
holy balls detailed. background much blacker than the geek out. Bass is articulate and it's definitely not a lush sound (was worried when Gavin mentioned they were tuning it a little warmer).
That gets me a bit worried. Geek out was too lean/cold/clinical for my taste. I had hopes on Gavin comment.![]()
The change wasn't for the sound, it was for the volume problems, which blasted my ears many times. I like the choice of filters as well. Can't comment on the change in sound, I had to stop using the GO and hadn't heard it for awhile until the firmware update came.
I've been comparing the original firmware to the beta firmware for sound quality instead of volume control like I was earlier and I'm pleasantly surprised! Music seems to be more spacious to me and the instrument separation is better (so instruments are better-defined within the soundstage). It's like the difference between listening to music in a narrow corridor and listening to music in a large room (I always found the Geek Out to sound narrow-sounding, this effect is removed with the beta firmware). Also, a kind of harsh sound that I'm used to hearing with the original firmware is now removed, which is really great news!
