krikor
- Apr 27, 2006
Not true, the X will be fully mono. The fi adds femto clock and upgraded components plus more digital inputs.
http://lhlabs.com/geekpulse3/images/Geek_Pulse_Soul_Technology_Breakdown.pdf
Correct on the fully mono. But where are you seeing more digital inputs? They are shown to be the same across all of the models - 1 USB, 1 TOSLINK, 1 AES/EBU, 2 SPDIF Coax.
As for how the transconductance amp is upgraded, that technology breakdown is not exactly clear. I thought different opamps were being used, but the same are listed across all the models from Pulse X through Soul:
OPA1612, LM4562, TPA6120A2, LME49990, AD827
And perhaps the following has been covered before, but it just crystalized for me looking at this chart:
There is an interesting situation for those who are considering the Soul - no single-ended headphone output is provided. You must have headphones wired for balanced use (no, a simple 1/4" TRS to 4-Pin XLR adapter will not do it since the TRS shares a common ground between the left and right channels). May not be a concern for those who can afford the Soul as many will already have balanced cans, and it is intended as a DAC and not necessarily a headphone amp. But I have several different pairs of cans, some that can be easily wired for balanced use (Sennheiser), others that need modification (Beyerdynamic).
Also, correct me if I'm wrong, but given that the headphone out is only balanced, you will not be able to listen to the tube output stage of the Soul Tube via headphones (unless of course you connect the single-ended outs to a separate headphone amp).
