BRMSlash
- Oct 29, 2014
The Project Solstice has officially been announced:
http://garage1217.com/garage1217_diy_tube_headphone_amplifiers_013.htm
From Garage1217's website.
I'm very tempted... need to save up some more cash
Key Features of Solstice:
- Compact footprint at just 5 x 5.5" fits most any desktop space with ease. Solstice is specifically an amplifier which is how we made her so compact. There is no pre-amp out on Solstice.
- Tube rollers DREAM. Just like our other designs, Solstice can accept a vast qty of tubes... but wait, there's MOAR! Solstice also features full Auto-Bias just like our Flagship amplifier - Project Ember! Drop a tube in and she will set things up quickly without having to fiddle with dialing things in. The only thing you have to select is heater voltage which is a manual selection with Solstice
- Cannot stand the (no volume range) syndrome that many amplifiers suffer from? This is a hated problem in which you barely have any volume range before it becomes painfully loud when using super efficient headphones. Solstice features a quick change attenuation module that can be changed out for higher efficiency headphones that do not require as much power - giving usable range on the volpot
- Solstice has outstanding power for the price point with a wide power band and power where it matters, especially with planar magnetic headphones. With over 1W available into lower impedance cans, and usable power to 600 ohm, Solstice will power all but the hardest to drive headphones
- Solstice has 3 output impedance settings. Select from .1, 31 and 68R
- Love current hungry tubes like the 6n6p or 6n30P? No problem! Solstice features a beastly heater power supply based on our Project Ember supercharger delivering over 1A+ of heater current without breaking a sweat
- UNIQUE FEATURE. Solstice can be equipped with a jumper setup that we call OHV. Not "overhead valve" as all you car nuts will figure... It stands for Optional Heater Voltage. This setting can be customized to allow either 7V heater output OR a true 12V heater output.
When combined with our 6SN7 adapter, Solstice can use more than just a 6SN7. She can also use the cheaper 12sn7 family of tubes. Talk about versatile! Our designs can already roll more tubes successfully than any amplifier on the planet... and we just added MOAR!
The OHV feature will not be equipped by default - but by request during the order. The reason is that if you pull a bonehead move and change things around without reading instructions or understanding what it does, you can kill a tube in an ugly flash of light. This feature is for instruction readers only and for experienced tube junkies.
