Following logic and science leads you to just shut the door to any possibility whatsoever of the usb cable making any difference in sq? Congratulations.
Look, I've had my fair share of tweaking my system. Sometimes it works sometimes it doesn't. I have a shakti stone to show for it too. There's a lot of bs around this hobby for sure, but happily not all of it is bs. I'm a big fan of blue jeans cable and before that Naim audio equipment (and back in those days no-one made cables for Naim gear). I was using a perfectly functioning usb cable and was part of the 'digital is digital' crowd when it seems a worrying number people are talking about usb cables. I read up on it and decided to try a couple out. One wasn't too different from my old cable and the other was significantly different. Then i got a few more and it appeared that i can more readily tell usb cables apart than rca interconnects. This was odd but again there appeared to be some explanations as to why. What's interesting is that folks who say usb cables matter aren't always people who make or sell them. Many aren't reviewers either. Google is your friend here, search and you shall find.
All i am saying is that if you trust in reason and logic, it should lead you to a 15 day return policy in a heartbeat. Many of these cables aren't expensive and many are very good. I will not say that spending $300 on a cable is worth the 'same' amount of difference if you spend it on other gear, but it can make your stuff sound better. It also seems to be dependent on the equipment involved. My pwd is not hugely susceptible but does improve while the gungnir shows the differences quite significantly. Try it. You don't have any thing to lose, do you?
@elmoe it seems odd that you paid 150 for a 1k cable. There are a lot of fakes and scammers around. Anyhow, what other cables have you tried (and found to be worthless)? I'd like to know what to avoid. A lot of places have good return policies - why not return them?
At the end of the day, we all have to live our karma. If mine means i must pay crazy sums for cables, well at least i ain't buying crack with it i guess.
