Chris J
Ho yes, it's such an important issue that there is regulation around this to limit the source of Electromagnetic Interference (EMI):
From Wikipedia:
"[COLOR=252525]In the [/COLOR]United States
[COLOR=252525], the 1982 Public Law 97-259 allowed the [/COLOR]Federal Communications Commission
[COLOR=252525] (FCC) to regulate the susceptibility of consumer electronic equipment.[/COLOR][COLOR=252525][6]
[/COLOR]
Potential sources of RFI and EMI include:[7]
various types of transmitters
, doorbell transformers, toaster ovens
, electric blankets
, ultrasonic pest control devices, electric bug zappers
, heating pads
, and touch controlled lamps. Multiple CRT
computer monitors or televisions sitting too close to one another can sometimes cause a "shimmy" effect in each other, due to the electromagnetic nature of their picture tubes, especially when one of their de-gaussing
coils is activated.
Switching
loads (inductive
, capacitive
, and resistive
), such as electric motors, transformers, heaters, lamps, ballast, power supplies, etc., all cause electromagnetic interference especially at currents above 2 amps
. The usual method used for suppressing EMI is by connecting a snubber
network, a resistor in series with a capacitor
, across a pair of contacts. While this may offer modest EMI reduction at very low currents, snubbers do not work at currents over 2 A with electromechanical
contacts.[8]
[9]
While a cable with a good shield will prevent radiative noise from those appliance, it won't shield against what is already in your electrical network. EMI transfer as well on conductive (so if it's connected on the same electrical network (which by the way it is, that's why we call it an electric grid), it can get by the cable).
That's why you sometime see cable that look like this:
It's a ferrite bead, it can be used to cut interference before it get into an appliance (one of the most effective and least expensive way). It can also cut interference going out of an appliance to meet government regulation. Now why the gov did regulate on this? Because it was cause issue. Electric network have to filter interference as well so they don't transfer between house, and to do that successfully, the best way is to limit them directly at the source. So yes your electrical network is clean enough, but there is already noise in it, but not enough to cause issue with your sound and nothing that your expensive cable will filter out since the shield only block what could radiate into it. And even then a Ferrite bead would be actually better, it will not only filter out the EMI from that got in on that 6 feet cable just before getting into your amp, but it will filter what was actually already on your electrical network. Personally I have already try a cable with one, and I did not notice any difference, probably because the equipment I use already have all the filter embedded in them or they are simply not sensible to them by the way they are designed.
I know it won't convince anyone, and since a cable with a ferrite bead is so less expensive then your $1000 cable, the placebo won't work as well. So you will actually notice a degradation in sound quality.
You're talking to the wrong guy.
I've performed EMC testing.
