I recently received this FX-AUDIO Tube-02 Pro from Amazon. It is advertised as being a class A tube amplifier. I do believe that it is. This tube amp's motherboard is the 2021-09-07 version 1.1. This headphone amp comes with GE JAN 5725W tubes. The FX-AUDIO website and the Amazon listing for this amp state that only 6J1 and 6J2 tubes are additionally compatible. I measured both the voltages and the resistance between all seven of the tube socket pins. It turns out that, at least for this amp's version 1.1 motherboard, any EF95 tube can be installed in the FX-AUDIO Tube-02. This has indeed proven to be true since I presently am using Voskhod Rocket 6ZH1P-EV tubes in this amplifier since tube pins 2 and 7 are connected to eliminate the military use of the sharp cutoff feature of the 5725W or equivalent tubes such that the stock 5725W tubes essentially become 5654W tubes in audio operation. Additionally, pins 5 and 6 for the tubes are also connected. I totally love the very clear tube sound since the even order harmonics from the tubes are strong in comparison to the odd order harmonics, and since all harmonics also properly and rapidly decay with increasing frequency. This is just the sort of thing which one desires for a warm yet clear tube sound. The Tube-02 Pro has extremely good signal to noise ratio. Notably, the Tube-02 Pro also does not contain any IC op amps. The output stage is driven by transistors.
I am totally new here. I am hesitant to write my first product review which would include product photos and internal product photos. I hope that someone else evaluates the FX-AUDIO Tube-02 Pro and creates a review for it.
