letsplaay
- Jul 15, 2013
Somehow the Shure black foam sleeves are too loose. Am I missing something?
Best earphones I have ever used. Previous owner of JVC HA-FX700, HiFIMAN RE-600 and 400, Audio Technica ATH-CK10, Yamaha EPH-100, Fischer Audio DBA-02. Goodbye head-fi. I am done for a good while.
Edit: bear in mind the MG7 costs near the same as the IE80 as Im in the UK.
Crikey, strong praise. Can you elaborate a little more before I order some Sennheiser IE80 today? I previously owned Hippo VB and Sony EX90EB.
i tried the IE80's rectanlty, and i can defiantly say i the atrios to me is better, BUT the IE80's were much better in terms of highs as it's much more neutral then the atrios, the mids are quite similar, i fell the IE80's sounded a bit better but not by much but now the biggest difference the Bass the IE80's got nothing on the atios as this is were the atrios shine, super duper deep bass and no bloat in the mid bass, don't get me wrong if you like a bit of midbass in your music then by all means the IE80's beats them atrios outright but in terms of subass quality and quantity i have really found nothing in compassion
soundstage is much larger on the IE80's then the atrios if that's what your after
so the question is what do you really want deeeep bass or a bit of both in good balance or allot of midbass and less subass (Westone 3 for that)
So the link I posted isn't the Atrio MG7 then? Something different?
