Tuco1965
- Dec 28, 2012
Monoprice is an inexpensive choice.
it seems like every developer forgets about us windows phone users
I read that the Fulla includes a short USB cable, and I was planning to connect it to my desktop. Will a USB extension cable work, any recommendations for something solid and cheap?
Can anyone compare this to the FiiO E12A?
I think that they recommend using a USB cable that is no longer than 2 feet long. You can probably safely extend this by using a powered USB hub or their Wyrd product between your computer and the Fulla (i.e., long USB cable from computer to hub/Wyrd, then short cabe from hub/Wyrd to Fulla).
It's actually 2m or less according to the Fulla FAQ.
Can anyone comment on whether the volume knob is really as bad as the guy in the Z Review video makes it out to be?
Also, are the edges of the metal casing really as sharp as he says?
Thanks!
I'd like some of whatever that guy was smoking/injecting/putting up his nose. The volume control is fine, ergonomically. Some have reported issues with the volume control having too narrow a range; I respectfully disagree.
