donjoe0
Previously known as abm0
- Mar 17, 2016
To reiterate something I mentioned in another subforum (because really it deserves its own thread here):
Dr. David Griesinger claims to have a method to achieve frontal localization and FR correction by using equal loudness EQ-ing (based on 1/3 octave noise bands) of a calibrated speaker set up in front of you, and then of your chosen headphones, with the difference between the two resulting EQ curves to be used for correcting your headphones' response in the end:
More details + presentations explaining the principles behind this are available in the first two 2017 updates on his website.
I've tried the method myself, I still have to work on it because I'm having trouble comparing the loudness of spectrally distant frequency bands, but I can say I've heard more frontal placement of virtual sound sources than with any (freeware/demo) crossfeed or binaural recording I've ever tried before. This is with my Koss KSC75 as the targeted headphones - I started with on-ears because Griesinger states at one point that this works better with in-ears and on-ears than with over-ears.
