Originally Posted by Mercuttio
So I take it the SA5k failed the bass test?
The SA5Ks are interesting
The bass on them is so tight I'm not sure if that's how the bass is supposed to sound or if it has distorted. It's very dependent on headplacement, the bass sounds totally different between :1.not sealed, sealed, sealed with hands cupped over
I'm having a very hard time with the SA5Ks on the bass issue
Is it crapping out? Is it distorting? Or is this is how the bass is supposed to sound and none of my other headphones have produced bass this "accurate"? I can't tell!
The non-bass portion of the SA5Ks? Wow, the detail and brightness on these things are exactly what I want in a headphone.[Or has the headphone brainwashed me into believing this is what I want?] These babies make the UE-10 Pros sound veiled in comparison. Now whenever I listen to the UE-10 Pros, I have to bump up the treble! Prolonged listening to the SA5Ks will change your perspective on all headphones. I want to put the SA5Ks together with the K1000s in this department(the changing perspective on all headphones department).
I may have to join both Team Bass Boost
and Team Treble Boost
The dissappointments of the SA5Ks? That it doesn't slam and vibrate like the HD650s. The bass is tight... but it has no impact.
In order to get any amount of bass you have to combine EQ + Bass Boost + Foobar Convolvor! These phones are bass shy!
The goods of the SA5Ks? That I will never ever listen to the HD650s without boosts to the Treble.(Is that a good or a bad?)
So what's my next purchase? I'm looking at the new Grado GS1000s. They look very interesting
