jessica00
- Oct 10, 2002
its EXACTLY why we have EQ's, that and for ever so slight bass boosts.
Originally posted by bobzemuda I strongly disagree with this!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Your ears can't hear it, but your body can feel it. I guess it might not apply as much to headphones as it would to a full stereo system, but your body can feel those extended frequencies. As I've mentioned before, I tape concerts. In that application, the extended frequencies that your body can feel lend the recordings a since of "being there." Another instance, would be a techno/dance club. They'll hit you with low end because you can not only hear it, but you can feel it. Bill |
Originally posted by engk: I could easily hear the 20 khz wav file. I guess this tells me to stay away from any phone that only does 20-20 khz. |
Originally posted by d_wilson The ER-4's don't stop working at 16kHz. 16kHz is the reasonable limit on the test format used. We are using an ANSI standard ear simulator for our tests. The acoustic impedance of the coupler drops off dramatically after 16kHz. Even when testing the $10,000+ Orpheus on this system (using the whole manequin) you will have the same problem. |
These and other headphones/earphones are just passive vibrating tranducers...there is nothing to stop it from reproducing high frequencies. |
Originally Posted by Ubijza This explains why piano, violin music sound flat and muffled on the CD - harmonics of these instruments are particularly rich and inedequacy of "CD revolution" is especially apparent. |
