Capt369
- Feb 28, 2007
Curious, has anyone directly compared the THX00 with both the TH900 pads and Alpha pads?
I`d still like some more input from peeps who have tried the alpha pads with these as well.
There are posts from others on alpha pads from earlier in the thread... some like them and some don't. (surprise, surprise)
They are okay with the th900 pads, but I prefer the stock ones on them. Not surprisingly, I also prefer th900 pads on the th900. In other words, I like them both with their intended earpads.
I currently have the Alpha pads on mine right now.
Here was my impressions I mentioned to someone else:
"Comfort is definitely far better! Does change the sound a bit, really cleans up the sound and improves the soundstage and imaging by a good amount. Though you sacrifice the mid-bass "bloom" which made the TH-X00 really fun (I personally really loved that sound because it was a great compliment to my HD800), but you do notice more sub-bass. It's too bad there's no pad that increases the comfort without altering the sound, but I'm willing to sacrifice some of the sound for far better comfort."
Are people really saying that stock pads are not comfortable enough? Really? I can't see any problem with them to be honest and they're OK after several hours.
I have found that with a shorter cable TH-X00s are reasonable for mobile use. Isolation is poor but then you might want that when roaming the streets at risk of being knocked over by cars. They're not too noisy, even though I notices a bit of a rattle while jogging. Get the Alpha pads on though and they become comically big. Who wants to go outdoors with two mini couches strapped tho their head?
You want to try really uncomfortable pads? Get a taste of Fostex' basic planars, the T50RPs Mk3. Not that's a modern torture device indeed. Lucky some $5 ebay pads easily fixed that.
Do you think sound isolation decreases with the alpha pads?
I've been juggeling between alpha pads and the stock pads, and have made up my mind. The stock pads sound better for me than the Alpha pads. Since my ears fit nice within the stock pads, there's no reason for me to use the alpha pads really. I'd ordered me Denon pads to try out, but they take forever to reach me it seems...
I think that how these sound with stock pads is relative to individuals ear sizes. The stock pads have quite small openings which can cause comfort issues but also make the bass uncontrolled.
The stock pads openings are too small for me.
Have tried a cheap pair of pads from ebay and HM5 pads.
Both are more comfortable to me and improve the bass quality.
The ebay pads are thinner than the HM5 pads, so mean my ears are closer to the drivers. The result is greater bass impact. The HM5's being thicker mean that the overall sound is a bit more balanced/bass has less impact.
Just my thoughts, others may disagree.
