bhd812
- Dec 4, 2003
Originally Posted by Quaddy /img/forum/go_quote.gif regarding battery life. this is what i do to get max life. i am not an edge user. so use services to disable edge daemon. bluetooth - same deal = off. only have SSH on when actively connecting into iphone, off all other times. use services to toggle these services as needed. auto-lock is a killer if set to never!!!! mine is 1min - makes a big difference to me. screen brightness. reduce it to a tolerable level. certainly not max brightness and turn auto brightness off when set to the desired level. if you have third party apps installed which have 'listening' daemons registered, these will run in the background constantly and reduce battery level. for instance, i use taskbar notifier, until recently it wasnt optimized and drained it bad. the new version fixes this. also, your mail settings. mine is set to 15mins auto check, and i do a manual check more often if required, not less - as this drains also with the listener, same for push email. theres probably more, but following those will stand you in good stead! HTH edit: i use mine as alarm clock also, all the time, with those other things 'tweaked' i have no problems getting couple of days out of it approx. |
[left]http://www.biocow.com/iCopy/[/left]
