foobar2000 + milkdrop/avs together at last
Jun 6, 2011 at 6:17 PM Post #16 of 36
I have mine "maxed out", but it doesn't use all of my CPU/GPU (i3-540/GTX470). Highest mesh but 30 fps, which is what my screen can display. It probably does look pretty cool with unlimited FPS tho.
I'm definitely not understanding. How can your screen only support 30fps??? And maxing out settings means no canvas stretch, maximum mesh size, and cranking up AA and AF on the GPU control panel, but that's overkill, and there are talks about AA doing bad things for user messages.
Jun 6, 2011 at 6:37 PM Post #18 of 36
Ahhh
I was really fearing that I some different kind of monitors were around that I wasn't aware of. Well, you can set basically any fps settings, from 1fps to unlimited, but I recommend you setting it between 30 and 60, as effects were made with that range in mind.
Jun 7, 2011 at 9:43 AM Post #20 of 36
GPU does make a difference with this. My old Radeon 9000 mobility can't even do the newer visualizations that have the PSVERSION=3 tag. It doesn't show a lot of the effects. Core i7-920 and Radeon 5850 can run pretty well on most things you throw at it. No where close to that cray though.
Jun 7, 2011 at 9:35 PM Post #22 of 36
Keep in mind that Milkdrop uses Winamp's keyboard shortcuts, and does perform quite well with those IMO.
About starting it up, you could always have a tab exclusive to Milkdrop open, so it would be visible once you start foobar2000, and would run automatically once playback began.
Unfortunately I'm not sure what more could be done about dual screens, as it worked natively on Winamp without tinkering. On foobar there were a few things to be done, but mostly, I think shpeck isn't fully reading all features just yet.
Jun 28, 2013 at 4:00 PM Post #23 of 36
Hey I was wondering what version of Foobar that you all were getting this to run on because when I follow the instructions posted in the first post, I get a directx run time error. Says something about me needing to install directx 9 and that seems a little hard to do on Windows 8. Any help would be much appreciated. Thanks.
Jun 29, 2013 at 1:03 PM Post #24 of 36
yea i got the directx error too when i install  in windows 7 took me awhile to find a solution in the end i installed this http://www.microsoft.com/en-us/download/details.aspx?id=34429 and it seems to make the visualizations be able to run
Nov 3, 2013 at 7:44 AM Post #25 of 36
This is no good because when you change the graphics settings it will not save and goes back to default.... Can you tell me how you make them save? eg. resolution, FPS, quality etc.
NVM fixed.... Don't like milkdrop much anyway tbh even on highest settings it looks a bit "90's" and low budget... Oh well..
Nov 3, 2013 at 2:18 PM Post #26 of 36
try this preset pack some really cool presets in here http://www.bitcore.org/stuff/BLTC2.1.zip
Nov 4, 2013 at 11:43 AM Post #27 of 36
Thanks, some of those are quite good actually... Is there a newer version of milkdrop (or a different one) which is more modern with better graphics? Milkdrop is pretty cool but it looks a bit retro like it was made in about 2001 or something for older computer hardware...
Nov 4, 2013 at 7:11 PM Post #29 of 36
I have not found anything better than milkdrop that's free at least, and I haven't tried any pay ones as most look inferior to milkdrop anyways.
  Also what are the best settings for milkdrop so that it syncronises with the music beats?
Don't think there are any it just kinda does what it does. i did find that if i changed the video setting it improved the quality but i run an intel i5 with a nividia gtx 660ti SSC 3 gb so i dont have many graphic card issues. my setting are like this...
