pkshan, does your program improve sound quality through reduced jitter? Do you have any measurements which suggest "foobar2000 HD" has considerably lower jitter than the regular ol' foobar2000 playing bit-perfect or otherwise? In addition, do you have any blind studies which suggest the difference (if there is one) is audible?
Do you have measurements and studies of FLAC vs WAV jitter as well?
That's how I converted my 100G flacs to wav in few ten minutes... :
1.In windows explorer, press F3, search *.flac
2.press ctrl+a to select all files.
3.drag & drop them to foobar diskwriter, then start conversion
