Foobar vs MediaMonkey
May 28, 2010 at 12:35 AM Post #16 of 63
Have only used Winamp until this point, but after these posts, will be downloading foob2k tonight :)
Apr 25, 2012 at 4:55 PM Post #17 of 63
Had to throw this in, I wonder if I might hear the difference between MediaMonky and Foobar and reading the post here, some subscribe to the believe they can. I say good for you. But even more compelling was a test done at Maximum PC in the various encoding formats. Good read and if you think your still a audiophile, well...
http://www.maximumpc.com/article/do_higher_mp3_bit_rates_pay_off
two cents
I just downloaded Foobar and going to play with it, now I wonder...
Apr 26, 2012 at 1:34 AM Post #20 of 63
Foobar ftw.
Apr 26, 2012 at 5:41 AM Post #21 of 63
iTunes FTW, best organization, and it works with my iphone.
As far as audio quality is concerned, lossless is lossless....
Apr 26, 2012 at 9:01 AM Post #22 of 63
But if it is modified by the OS mixer it defeats some of the point.
On Mac OS we have options like Bit Perfect or Audrivana to stream bit perfect files to our DACs with iTunes, to my knowledge it's not possible with iTunes on the PC.
On the PC I used to love JRiver with WASAPI. If I ever get another PC it's the first app I'll install.
Apr 27, 2012 at 12:10 AM Post #23 of 63
I'm all foobar'ed as well. I tried MediaMonkey first but for some reason, it was making all my FLAC files sound subdued. I ended up with foobar2K and the ASIO4ALL plugin and it opened things up a bit. It's pretty obvious to my ears but not sure if this is normal.
Is there a foobar optimization guide out there that's helped folks maximize their usage/sound quality from it?
May 1, 2012 at 10:39 AM Post #24 of 63
I just installed foobar and it's not user (i mean idiot) friendly in my opinion. It'll take awhile for me to figure out how to organize my music on here...either myself or this program isn't very intuitive.
May 6, 2012 at 12:13 AM Post #25 of 63
Personally I find Mediamonkey gross to look at and hard to manage
Pic related
May 6, 2012 at 8:00 AM Post #27 of 63
I can send you the configuration if you want. Just install Columns UI, along with whatever else you might need
May 6, 2012 at 8:54 AM Post #28 of 63
I downloaded both Foobar, as well as MediaMonkey when I realized I could not send 24/96 HDTracks flac downloads to my iTunes library. Since Foorbar appeared easier to master I gave more attention to it. But, because I have such an affinity for iTunes, I also downloaded DBpoweramp, using it to convert flac to alac. I discovered DBpoweramp is good for finding art too.  I'm happy with all outcomes: Foobar, DBpoweramp, 24/96, iTunes, and alac although, not using all of this stuff everyday, I cannot navigate as painlessly as I would like. I have saved the flac downloads and on occasion I have compared them from Foobar with alac conversions played with iTunes. Using an external sound card (Sound Blaster X-FI HD) to convert USB to S/PDIF for pickup at my control amps DAC I perceive that the tunes played from Foobar sound better; however, the folks at Foobar tell me all media players sound the same. At any rate, music has never sounded better to me than right now. I'm happy with it all, the quality sound and convenience. Only thing I wish for is that  BD audio takes off as listening to Diana Krall in Dolby Digital vs. stereo is no contest. Dolby Digital is just awesome.
May 6, 2012 at 11:30 AM Post #29 of 63
I really don't think all players sound the same. Even on Media monkey using the WASAPI and ASIO plug ins for bit for bit playback, there is a difference in sound (I prefer ASIO).
May 8, 2012 at 3:43 PM Post #30 of 63
Unless you have plug-ins installed on either media player, there should be absolutely no difference.
