When I had the Yggy, I could turn the Nautilus' volume knob 2 clicks (from 6 o'clock to barely 7 o'clock) before it was too loud. With the XLR cables plugged into the attenuators, set to -15dB, I could comfortably reach past 12 o'clock. As far as degradation of sound, Justin (ampsandsound owner) recommended the attenuators because he didn't think it would be audible and I didn't hear anything, but I was just happy to have more than 2 clicks of volume.
I'm listening to my Utopia 2022 as I'm typing. with the Mojo Mystique X dac feeding the Nautilus using RCA cables, and I don't have any need for attenuation because I can turn the volume knob to 10 o'clock. Same with the Stellia.
I don't see any specs on the Mojo Audio website or my manual but I'm assuming my dac has the standard 2V SE output.
I tend to like both the Focal and ZMF house sound, and IMHO have found both LTA and ampsandsound amps to have great synergy with both brands. I've owned 2 amps by each manufacturer.
I bought the MZ3 at CanJam last year after plugging in both my Stellia and a ZMF Atrium into every amp I could get access to. I wouldn't say that the MZ3 is soft per se, because that sounds like a negative. The best description I ever read was in
this review, which described the "edges of sounds as feathered a bit", which gives you hour after hour of pleasurable listening, because there's no harshness.
I upgraded to an LTA Ultralinear+ this year, partly because I needed more power for my speakers, not because I was disappointed in the sound of the MZ3. The UL+ is more detailed and doesn't have the "feathering", and although I prefer the UL+ to the MZ3 as an everyday listening amp, I often miss the sound of that MZ3, and I wouldn't be surprised if I buy another one.
The Ultralinear+ and Nautilus are both unbelievable amps, but I tend to use the UL+ more because the tube life is greater, so I can leave it on all day without worrying about my expensive tubes having the life drained out of them.
The big advantage of the Nautilus is it's ability to drive almost any headphone (I have not tried it with a Susvara, but it easily drove a HE6SE V2). Outside of the attenuation issue (which I no longer have), it sounds wonderful with both sensitive and harder to drive dynamics, and also has the current to drive planars. I also love all the different taps that Justin provided, which allow me to dial in the sound of the headphone to match my preferences. For instance, when I was testing the ZMF Atrium Closed, I found the bass a little overwhelming on some tracks when using the stock lambskin pads. Zach advised me to switch from the 100 ohm tap to 32 ohms, and bingo, the bass was both lower and tighter.
