marcr
- Apr 4, 2011
But you can’t see the settings!Here is what Dynamic EQ looks like in iOS
I'll trade with you!Ha, so you Apple people got Dynamic EQ, and us Android people got Sidetone. Guess one can't have it all! xD
Haha, I'd be in, can send you my old and battered HuaweiI'll trade with you!
Try to reset the app by clearing the data in the app settings from your Android settings menu. I had to do that for the dynamic EQ to appear.No "Dynamic" setting for me on Android either.
The Sidetone setting is a check mark in the cogwheel menu.
Wow, man, how did you know? This works!Try to reset the app by clearing the data in the app settings from your Android settings menu. I had to do that for the dynamic EQ to appear.
Settings -> Apps -> Focal & Naim -> Storage & Cache -> Clear Storage.
Happy it worked for you too! I've had issues with other apps not updating properly in the past and clearing storage usually did the trick, same thing here with the Focal app!Wow, man, how did you know? This works!
That weird behaviour is just because you switched to a dark app theme. You can swipe close and restart the app and it should be fine.In Android, long press the app icon and select app info. Goto storage and cache, and select clear cache and clear storage. The app will start with its install defaults. Attached are the screens, and the weird behaviour (sceeen #3) when the Dynamic Eq options is selected. No testing lol.
Kudos to @Nomax for my custom settings which are perfect and made Bathys shine.
I actually have the LCD-2 as well and the Bathys. The Audeze sounds much better but here is the big qualifier. I’m using a balanced cable which lets even my Paw S2 drive it easily, but my gear with unbalanced 3.5 can’t kick out enough juice to make the magic happen. My A&K SP3000 has to go up to like 130 to get the same volume I’d get on the LCD-2 at 60 or 70How do they compare to your LCD-2?
Presumable you've updated both the app and headphones themselves? I'm on iOS and it all works fine, apart from the missing Sidetone settingI‘m iOS User, have updated but can‘t see the dynamic mode. Do I have to do something else?
