ctrlm
With your testing, how you would compare the DAC's between the Arche & ADI-2/Qutest?
Well, as you know there is an objective train of thought that all DACs sound the same and I subscribe to this theory maybe 70% based on my experience. The exceptions so far for me have been R2R and multibit type DACs. For example, I could not tell the difference between the DAC in my RME ADI-2 and a Topping D70 in both sighted & blind testing - they both use AKM chips, albeit different versions. I have also found it hard to pick any difference between AKM & ESS Sabre DACS in the past but I swear that listener fatigue kicks in much earlier with the Sabres.
Anyway, the Qutest is different to my ears and as I said previously has a cleaner and tighter mid bass compared to the DAC in my RME and I think the high mids and highs have a smoother presentation to them without losing any clarity or detail, in fact the Qutest might actually be better at fleshing those details out.
So on to my limited comparison with the Arche, where I found exactly the same. The problem is that so much depends on the track you are listening to and there were times when I preferred both of them. Sometimes the bass of the Qutest sounded better - punchier & cleaner and sometimes that bit of bass bloom in the Arche sounded really nice and the Qutest sounded a little dry & sterile in comparison. With the Arche on the the Clear amplifier setting, I find it somewhat tube amp-like and that it makes the highs smoother and darker than the voltage setting, I probably preferred using the Arche DAC here. Full disclosure though, I do use some subtle EQ with the Clear amplifier setting:
Anyway, I couldn't say that one was significantly better than the other, so the one box solution won out - I put the Qutest back in the cupboard for now. The days of me comparing equipment for days on end and looking for minute detail differences that are more often than not - imagined, are long gone. I think Focal has done a great job with the Arche apart from the handshake & firmware issues.
On a different topic......I solved the problem with the sharp metal feet. I just stuck the supplied pads on to them with a dab of super glue
