So I just got the Flux FA-10. I'm comparing it with my Jot 2. Both connected to my Bifrost 2. So far there is no really noticeable difference between the two amps. The vocals are perhaps a bit more forward on the Jot 2 and maybe a bit more bass as well. The FA-10 perhaps gives a bit more separation between instruments while vocals are a touch more recessed. Details are the same for both amps. Despite the FA-10 boasting 16 watts per channel I have to put the volume between 12 and 1 o'clock compared with the Jot 2 which is between 10 and 11 o'clock. I also didn't anticipate the FA-10 being so much bigger in size compared with the Schiit gear.
Flux Lab Acoustics FA-10, FA-10 Pro, FA-12, FCN-10 & FA-12s Amplifiers - Summit-Fi for the People?: Reviews, Impressions & Discussion
- Thread starter teknorob23
Are your headphones the ones you have listed ? If so I probably wouldn’t have picked up the flux FA-10 just my opinion.So I just got the Flux FA-10. I'm comparing it with my Jot 2. Both connected to my Bifrost 2. So far there is no really noticeable difference between the two amps. The vocals are perhaps a bit more forward on the Jot 2 and maybe a bit more bass as well. The FA-10 perhaps gives a bit more separation between instruments while vocals are a touch more recessed. Details are the same for both amps. Despite the FA-10 boasting 16 watts per channel I have to put the volume between 12 and 1 o'clock compared with the Jot 2 which is between 10 and 11 o'clock. I also didn't anticipate the FA-10 being so much bigger in size compared with the Schiit gear.
My headphones are the HD6XX and ZMF Aeolus. Why would you have not chosen this amp for these headphones?
I believe that amp was tailored to planar or highly inefficient hps and you have a dynamic and what I believe is a bio cellulose driver which I don’t think you are getting the most out of that amp with said hps.My headphones are the HD6XX and ZMF Aeolus. Why would you have not chosen this amp for these headphones?
So I should buy planar or highly inefficient headphones? I think the only planar I've had was the Audeze LCD-2C.
I’m not trying to tell you to buy anything I’m just saying might not be a real synergy purchase for what you currently own and I’m sure enjoy. If you’re venturing into planar and something like the he6 or susvaras I think it’ll add value to your flux FA-10 amp.
If you want a good Solid State option for those, I’d think the FA-10, with its spaciousness and detailed upper frequencies, would bring some life to both of those headphones. That being said, its sound is fairly neutral, so a higher end OTL or other tube amp might let you enjoy the 6XX and Aeolus more than a higher end solid state would.My headphones are the HD6XX and ZMF Aeolus. Why would you have not chosen this amp for these headphones?
I also agree with wazzupi, this amp really is built for harder to drive planars, or anything with a low-ish impedance but also low sensitivity.
wolfstar76
I have HE6SE, which is extremely hard to drive, and that is the major reason why I bought FA-10 since at the power level FA-10 is relatively cheaper. For 6xx, you do have a lot more choices to make.
What about the Hifiman Ananda? I got the FA-10 cause it seems to have overall positive reviews. I've also been looking at amps like the SingXer SA-1 or Rebel Amp or Bottlehead Crack.
BHC is a definite win with your headphones! I enjoy mine with my Aeolus and 6XX regularlyWhat about the Hifiman Ananda? I got the FA-10 cause it seems to have overall positive reviews. I've also been looking at amps like the SingXer SA-1 or Rebel Amp or Bottlehead Crack.
I personally don’t think the Ananda’s need that that amp but it’s more of a step in the right direction for that amp.
I agree OTL tube amps + dynamic drivers and high impedance headphones is a win !!!
My first love was the OG La Figaro 339 and the hd650 back in 2009 xD
RenEh
- Apr 28, 2017
IMO the Ananda is well powered with the fully balanced FA-12. Might as well enjoy the refinement of a fully balanced amp.What about the Hifiman Ananda? I got the FA-10 cause it seems to have overall positive reviews. I've also been looking at amps like the SingXer SA-1 or Rebel Amp or Bottlehead Crack.
jonathan c
• When you read those reviews, did you gather for what headphone(s) the FA-10 might be a best match? Was there anything in those reviews to indicate a great FA-10/HD-6XX or FA-10/Aeolus match? I sense mixed motivations in your acquiring the FA-10.What about the Hifiman Ananda? I got the FA-10 cause it seems to have overall positive reviews. I've also been looking at amps like the SingXer SA-1 or Rebel Amp or Bottlehead Crack.
• Do you really like your Aeolus and 6XX? Do you plan to keep them? Yes? Let’s work ‘upstream’. @wazzupi, just above, understands one of headphone audio’s basic ‘laws’. So for your Aeolus and 6XX, it is high output impedance OTL tube h/p/a time. In this arena, there are a number of reasonably (non exorbitantly) priced candidates: Bottlehead Crack + Speedball, Eufonika (a few models), Feliks Echo, Feliks Elise, Woo WA2, Woo WA3 just to start. [Note: Valhalla 2 does not qualify here since it is a low output impedance OTL tube h/p/a.] This is where you should be looking if you want to maximise the musicality of what you hear from your system.
• Matching a amplifier to a headphone is far more likely to bring musical satisfaction than matching a headphone to an amplifier.
