Love your new avatar!My FA-12 has shipped Hopefully 7-10 days and should be with me
I have a full scale copy in my kitchen!!!
We’re off topic, but I updated the firmware and found zero difference using non usb outputAlso if you have a Denafrips Dac you really need to get the latest firmware 3.12.0 from here https://www.denafrips.com/firmware-update-usb. It is a huge improvement even on coax.
If you are on 3.6.0 you may not have noticed a difference they were very similar. The prior Kernel was bass light. At least your up to date.We’re off topic, but I updated the firmware and found zero difference using non usb output
@sahmen @Slim1970 @ksorota
Any chance there are still modded FA-10s floating around? I'm not sure how many are in the wild, but I would love to try one out to compare to the stock FA-10. I'm trying to decide between buying a FCN-10 or waiting for a modded FA-10. My concern with the FCN-10 is that it probably has less room to put in bigger caps, plus don't need the DAC or streamer functions.
There are, but with new owners. I moved on from mine. If you can find one that's already modded it's more than worth it. It drives everything and sounds good doing so. On the other hand, you can always have @ksorota mod one for you. That's if you get a new one.@sahmen @Slim1970 @ksorota
