Victorfabius
Also a side by side picture including the Pro Gold would help too, I'm trying to see if the Pro 2 and the Gold are similar shapes and profiles in the entry and rear port.
Pro 2 is slightly bigger than the Pro 1. About a 1mm diameter or circumference difference. Eyeballed it for official measurement listed.
Pro 2 has a significant increase in the rear vent over Pro 1. It is noticeably deeper and wider than on the Pro 1.
Pro 2 is smaller and lighter than the Golds. Need more time to compare.
Weakness of Pro 2 is again the cable termination. The plug will break with less applied lateral stress than any other I've encountered outside of Flare.
No sonic impressions yet. Been listening in poor conditions.
Currently listening to the Planamic on Note 9 since I found the EQ settings. You'll likely see the Planamic offered for sale in the forums. The only advantage the Planamic has over the Flares (pick one, it does not matter) is the replaceable cable. Just putting that comparison out there.
