Hello Head-Fi'ers,
I will be purchasing my first pair of $100+ IEM's soon and I have been researching the Flare R2A and Trinity Delta models specifically. I am wondering if some of you who have listened to both pairs to some extent could give a quick rundown of the two and comparison, as well as a recommendation. I mainly listen to electronic music and appreciate quality bass. I have the option to purchase the Flare R2A ORG anodized orange aluminum pair from Amazon for $150 and the Trinity Delta V2 from Trinity's website for a $100 pre-order payment. At these prices, which pair has the best price per quality? If you believe that there are better options than these, I would love to hear about them and why you believe they are better. I would like to spend $100-$150, but I am willing to spend up to $200 or possibly a little more if there is a pair that is thought to be truly exceptional.
Thanks
Brandon
This post is kinda long so I have a TL;DR at the bottom
You've posed a tough problem there buddy
. Because I find both to be quite good for EDM. In terms of bass quality, the R2A does better in my opinion. It goes a little bit lower and has better texture and control to it. That said, the Delta is no slouch either; it's frankly at a disadvantage in this comparison because I happen to think the R2A has some of the best bass reproduction I've heard in an IEM. However, to my ears, the Delta wins overall in the mids and treble, even though I'd pick the R2A to have a little bit more clarity. The Delta has a little more musicality to it.
Keeping in mind that I do consider the R2A to have some of the best bass I've heard from an IEM, I'd recommend the Delta in an overall battle. The Delta sounds more suited to multiple genres to my ears than the R2A and EDM is realistically a melting pot of far more genres than you'd initially think. It also wins my overall vote against the R2A because it's built better too. The shells are still milled aluminum, but the cable entry into the housing is properly relieved and so is the jack itself, which uses a spring-loaded relief (which if it's gonna be a straight jack, it might as well be my favorite relief type). The cable itself is also a very nice quad-braid cable, not to mention the fact that I think the V2 might use detachable MMCX connectors (you'll have to fact check this since I could very well be talking about the other Trinity Audio models). I also don't know about the production R2A accessories, but my Kickstarter one literally came with a cloth bag (far too big considering how small the R2A is) and 1 set of Comply tips. The Delta, on the other hand, came with 5 sets of silicone tips, 2 sets of foam tips, and a case that is appropriately sized (along with the 3 tuning filters for V1, I believe V2 has 4 or 5 filters).
Sounds like I'm really touting the Delta doesn't it?
Here's a TL;DR:
If you want the IEM with the better bass quality and slightly better sound stage with a touch more clarity at the cost of having an abysmal accessory package and a comparatively worse (but not exactly terrible) cable, then pick up the R2A. If you want something that can perform better as an all-rounder with only slightly less bass quality and treble clarity, but better midrange and overall musicality as well as a better cable and accessory package, then get the Delta. As noted earlier, the Delta also comes with some different tuning filters to play around with that one might like better than the stock filter.
Both are great IEMs, I just feel the Delta is a better overall package, so that is my pick and recommendation.
