You guys aren't paying attention.
I TRIED rolling tips, basically skimming over the Complys because I didn't like them in the first place. I Have a HUGE amount of different types, but I whittled it down to what I thought sounded the best. After an extended 8 Hour listen, I was Totally Un-happy with the sound of the R2As and ready to throw them into the Drawer and forget about them. PLUS, I posted a first impression a while back, not being very kind to them. Several Guys commented and advised me to use THE COMPLY TIPS, (to which I have a real aversion having had less-than-desirable results in the past with many other earphones).
Apparently the FLARES are designed FOR these tips. I retried them taking great care about preparation and deep insertion. I was amazed and rewarded with GREAT sound. WHO KNEW? Yes the Complys are a PIA to use, and they wear out rather quickly, BUT they work exceeding well with the Flares.
Try them again. These are NOT Bass light by any means, that is your first clue you don't have the right tip. The 2nd clue is DISTORTION at a good volume, particularly if you boost your Bass, because you don't have the right tip.
CATCH 22? When you use the complys these problems are eliminated.
JMHO
TWIN
