Flac v Wav
Apr 10, 2009 at 3:08 AM Post #31 of 54
Originally Posted by myhandtel /img/forum/go_quote.gif
yes, in short lossless->realtime decompressing->more workload->more noise
Do you a reliable source for this logic?
many people can abx wav and lossless but i can't, so i just stick to lossless
Low bitrate yes - high bitrate, not conclusively.
Apr 10, 2009 at 3:45 AM Post #32 of 54
I dont think it is reliable because it's just a pc with a graphic card, lots of noise.
I know a friend use modded psu, modded motherboard with mobile cpu,
and ssd for os only. Then disable all other chip at the mother for ultimate result. And the power consumption is very low.
Sometimes I can hear some differences at his computer. But I never noticed the high low bitrate is a matter. I think i will look at it.
Apr 10, 2009 at 6:43 AM Post #33 of 54
Who are these "many people"? I don't suppose you have any evidence? Also i trust it's something more reliable than some guy saying "hey I just ABXed wav vs flac" without anything to back it up.
Apr 10, 2009 at 10:55 AM Post #34 of 54
Nobody can ABX wav from Flac, because there is no difference. It can be even measured that it is 1:1 copy. For example, even if the difference between high bitrate MP3 and CD/WAV is (almost) inaudible, it cant fool measurement softwares and difference is clearly visible. FLAC is essentially just ZIPing that is dedicated to audio compression and tag support added, original audio file is completely unmolested. Anyone claiming they can ABX the difference is talking out of their arse, honestly.
I can imagine some problems might arise if your computer is 100% taxed and is unable to decompress it in realtime, but I havent tested this. Even then I GUESS it would only produce choppy audio at worst as it has to stop and load more data to play. Computer noise is pretty much irrelevant if external DAC is used and it is away from other electrical noise, but this applies to CD players aswell.
Apr 10, 2009 at 11:04 AM Post #35 of 54
Bitrate on FLACs doesnt stand for soundquality, only how small the compressor has managed to compress it. AFAIK you cant even adjust it yourself much, much like you cant really adjust how small ZIP/RAR can compress your file, (only how strong algorithm is used can be changed) end result is what it is.
Apr 10, 2009 at 11:36 AM Post #36 of 54
err...right
Originally Posted by dazzer1975 /img/forum/go_quote.gif
What flac settings do you guys use? Im thinking 5
well 8 of course....but APE in insane mode compresses way better anyway
Apr 10, 2009 at 12:32 PM Post #37 of 54
Nonsense, stop trolling please. Only if you are running a pentium 1 you might get into some trouble and probably not even then. The workload to decompress FLACs is simply too low. Like Maza mentioned you won't end up with noise, but without sound or choppy sound.
Read the comment above - the nonsense part. There are hardly any people who are able to consistently tell the difference between a high quality lossy file and a lossless one. Let alone tell the difference between one lossless format and another. You can look up the results of various tests on this very forum. Read up on the subject before saying things which are simply not true please.
Edit: Quote:
What flac settings do you guys use? Im thinking 5 as its default but wondered what the consensus was amongst you flac aficionados
I think it depends mainly on what CPU you've got. If you've got a fast Quad Core (or even faster) I wouldn't hesitate to use FLAC 8, if you've got a slower CPU you might want to use lower settings. Just make sure you won't have to wait too long.
Apr 10, 2009 at 1:32 PM Post #38 of 54
Hmm ok, this talk of decompressing putting a strain on the chip and thus perhaps employing lower compression that flac 8 as I have a dual core not quad core chip, how does this affect the useage of flac on dap's?
I do listen to music on my computer but also a lot of it is through my dap's so presumably for the flac capable dap's I would also have to be mindful of the level of compression used incase it ran into trouble decompressing?
Is that right?
Apr 10, 2009 at 1:46 PM Post #39 of 54
Higher settings do not affect the decompression speed, just the time it takes to compress the file in the first place. See:
FLAC - faq
Apr 10, 2009 at 2:12 PM Post #40 of 54
Originally Posted by Acix /img/forum/go_quote.gif
I'm trying to see how I can benefit from FLAC by using it with Nuendo or WaveLab.
FLAC only works with integer bit depths so would not be compatible with Nuendo or Wavelab. Even if it were compatible, you would not want to add the additional processing overhead when processing a number of individual channels during mixing.
G
Apr 10, 2009 at 2:40 PM Post #41 of 54
IIRC cpu usage with flac is very low; probably as low or lower than mp3.No modern PC or portable player is going to have any issue with playing them.
Apr 10, 2009 at 2:42 PM Post #42 of 54
Yeah, but that was just an estimation of what-if situation, like some program has already brought your CPU to its knees and then you try to add flac playing on top. But it still might be easy enough to not chop audio.
Apr 10, 2009 at 3:34 PM Post #43 of 54
FLAC - faq
excellent, thanks for that and the link also.
Thanks to everyone else too for answering my questions and providing the advice and info needed.
Apr 10, 2009 at 5:56 PM Post #44 of 54
well a placebo maybe. Until we can find something to measure it.
Apr 10, 2009 at 6:58 PM Post #45 of 54
Yeah, right!
As mentioned by others, if your CPU run out of cycles decoding the FLAC file (very unlikely) you will just end up with choppy music. There will be no noise.
FLAC decode real-time on portables with ~100-200MHz processor, so I doubt your 2-3GHz processor will run out of steam...
