philodox
- Dec 12, 2003
Of course, that is always a possibility. However, as I stated in the second part of my post, there is certainly precedent for software/decoding issues causing audible differences between FLAC and WAV. I think it is likely that Patrick is hearing a difference, but I think his reasoning as to WHY there is a difference is ultimately flawed.
Chad - I believe the squeezebox is capable of playing WAV natively, while there is a separate chip which decodes the FLAC. My hypothesis is that this separate chip does not do its job all that well. Also, to confirm, my comment is based on my experience and listening tests. I'm not just repeating what others have said. When I had the squeezebox I ran into this issue and in my searching afterwards I came across others with the same problem. While this may not confirm the phenomena for you, it is enough for me to discount placebo as the cause. Perhaps if I had prior knowledge of the issue there would be more of a reason for skepticism.
Originally Posted by nelamvr6 /img/forum/go_quote.gif Do you admit that it is at least possible that there is no difference and that Patrick is experiencing placebo effect? |
