lan
Videographus Supremus:Makes audio cables using super-advanced materials, like "some clear tape" and "some not so clear tape."
- Sep 4, 2002
The money analog is not meant to be directly related. It's just to show there are somethings which make a difference besides satisfying accounting which is like engineering in this case. Yes the computer system is highly controlled environment but it has a range of working parameters in which there are variances. Music playback is not a direct function of any of the subsystems. It's a results of various combinations of functions. You might say the interactions are significantly narrowed down but there are still infinite points between 1 to 2 vs. 1 to 5.
Another example. A band is a mix of instruments with specific functions. They can work within paramaters (frequency boundaries). You can identify the same songs being played (binary yes or no) but they are never played back the same.
While the data output is the same, it's a different process using FLAC. It's different software, different load, etc. The end results will be slightly different if playing back. Recording/storage will yield the same result.
You don't need to explain to me what digital is. You guys are correct in what you are saying. I'm just trying to state there's more to this than just being "digital". The world is more complex that just that. My examples provide something more tangible in general life where as speaking of things inside a computer is not as tactile.
