OK, so can you attempt to explain why it's only the reflected EMI and not the direct EMI that causes these putative problems? (Note that I wrote "attempt", because your premise is, sorry to say, ludicrous.)
All electromagnetic radiation follows the inverse square relationship. If the direct route between components is, let's say, 1/5 the distance to a completely reflective surface, the reflected interference would travel 10 times as far as the direct interference, and thus be only 1/100 the strength of the direct radiation.
How do you know the precise direction at which a device projects its EMI?
Originally Posted by Patrick82 /img/forum/go_quote.gif Why wouldn't it? All components generate EMI which interfere with the other components. I changed my 1GB RAM into 512MB and it sounded worse (should have sounded better), then I found the reason, my 1GB module has a metal casing around it which keeps some of the EMI inside it. Shielding the RAM should give bigger differences because the direction of the EMI is facing the mainboard. .......<<snip>> |
