castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
I agree with that, actually. There is a general lack of caution when claiming something, and that's found on any side of any argument. But of course, some things are factually established and considered scientific knowledge. No point in presenting those as personal opinions.I think the problem lies when some claim their opinion is science and that any dissenting opinions are not going against an opinion, but science itself..
Those instances are very likely an Appeal to Authority. A well-known logical fallacy.
What annoys me just as much as trying to make something look proved when it hasn't been, is how often people won't take it as that one person claiming something, but will instead start to oppose, the entire subsection or even Science in general. It's weird, obviously easy to do as it happens so often, but weird nonetheless. I disagree with that one guy, you know what will make it easier for me? If I start fighting an entire group or the very concept of science instead.
24bit is irrelevant because nothing can replay those LSBs. You can do whatever you want to them, they won't come out on any sound system.Why does rounding cause audible distortion in 16bit, and especially 8 bit, but not, say, in 24bit?
16bit probably wouldn't be audible unless you go for extremely quiet signal and high playback level(to bring the LSB level somewhere you can hear it, and it won't be entirely masked by the louder music). All the times someone talked about passing such a test, he used that trick instead of typical music at typical listening level.
8bit LSB is still loud enough for a lot of the lowest signal to not be masked by louder content. But as mentioned, with noise shaping, even picking up 8 bit noise can be challenging.
Distortion or noise is just a nomenclature thing. In general, correlated errors are called distortion, and random stuff, like the wife talking while you listen to music, that's noise.
But of course that would be clear and simple, so someone introduced the concept of correlated noise, just to mess with us.
