Sep 20, 2011 at 9:00 AM Post #18 of 123
I am 99% going to buy the E17 too.
Please add the possibility to turn off usb charging when connected to an usb-port. The reason is that the E17 should not drain the battery of an Android device while connected to its usb-host.
Thanx in advance :D
Sep 20, 2011 at 9:35 PM Post #20 of 123
I like the design. Look better than E7.
About the function in the firmware, how about adding crossfeed in. It will add the value of E17 more.
Sorry, E17 will not support the crossfeed in .
Sep 20, 2011 at 9:35 PM Post #21 of 123
Thanx in advance :D
Yes, you can turn off the USB charging like E7
Sep 23, 2011 at 5:22 AM Post #23 of 123
So, this will have a noticeable SQ upgrade over the E7, right?
Sep 23, 2011 at 6:29 AM Post #24 of 123
SQ and more feature.
SQ: 96/24t@USB 192/24@coax/optical , better amp
Feature:  more input, balance, bass&treble, gain switcher, hardware hold switcher.
Sep 25, 2011 at 10:16 PM Post #26 of 123
The bass&treble could be adjusted while dock with e9?
It is a big problem, some need a pure line out bypass the volume and the EQ, some need EQ and volume control. LOL. let me see if we can solve this question.
Sep 29, 2011 at 4:36 AM Post #27 of 123
We decided to add a switcher, so you can select or get the pure line out through the dock, or you get the pre amp signal through the dock, the pre amp output siganl will go through EQ.
