Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
Well it was messy! It took me two tries to complete the cable and even now I wonder how long I can use it for before it falls apart
and yep I used heatshrink to wrap the cable from head to foot--not the most elegant solution there is, I'd say
I originally composed this as a reply to a thread about DIY Clou Clones and I'm too lazy to modify it, so refer to that thread when reading this post.
I'm wondering how your DIY cable project went? I just finished making my first DIY IC. (male mini to mini) Basic plan was much the same as your Clou clone, except I didn't braid the wires (and of course, I was making an IC, not a HD5/6xx cable). As I was making an attenuator cable it was quite a bit of hassle (wiring the resistors in the middle took up half the time
). At the stage when I had just wrapped the wire in foil, it looked really hilarious--like I was wrapping up a turkey to put in the oven to cook or something
Of course there's no foil wide enough to wrap the whole wire in one go, so I wrapped it in 3 or 4 sections. I put one layer of heatshrink between the signal wires and the foil to increase separation and hopefully decrease capacitance.
I tried testing its RFI rejection by turning on and off a mobile phone next to the cable while playing music--I noticed no significant difference between when the cable was grounded and ungrounded. If anything, it seemed better before it was grounded, but I really don't know, because I only tried it once, and in any case, it's all wrapped up in heatshrink tubing and hard-wired to connect to ground on one side.
The end product is so stiff I feel like tying the two ends of the IC together with string and using it as a bow!
Well that's a bit of an exaggeration but it *is* not so easy to even make the IC loop in on itself! LOL I wonder if Clous are anything like this!
On a side note I used regular copper cable, 26AWG, and the wires are stranded, which made it rather hard to work with (I keep breaking half the strands when exposing the wire from the insulation and when bending it to solder to the plugs. Even now half the strands are broken on one plug and I wonder how long it would last
I also wonder how important the continuity of the foil shielding is to its effectiveness as shield. On the foil I measure negligible resistance from one end of the cable to the other (<10 ohms) but I can only imagine that if the shielding does not consist of one solid conducting cylinder it is harder for magnetic fields and such to induce the smooth circular(-ish) currents in the shield...
![tongue.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/tongue.gif)
![redface.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/redface.gif)
![eek.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/eek.gif)
![biggrin.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/biggrin.gif)
![frown.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/frown.gif)
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
